All the talk of the new TF front grill, has got me wondering..
I'm curious.. what engine will Nanjing be sticking in the new TF?
Heh.. let's hope so, eh!Read about the N-Series they have sorted the heating sensor issues and made HG Failures a thing of the past :O
That's Snipers day obviously ruined, then! :sad2:Nooooooooooooooooooooooooooooooooooooooooooooooooooooo......!
Nooooooooooooooooooooooooooooooooooooooooooooooooooooo......!Yes. There will be no VVC model
I was referring to the head gasket / reliability issue.....Doubt it TBO unless its significatly more reliable and tunable then the EU3 engine. Certainly the above didnt really happen when either the EU2 or EU3 engines where released. The power increase can still be obtained through tuning your existing engine for less then the cost of a new engine. In fact it would still probably work out cheaper to drop a 145BHP VVC or 160BHP VVC in.
Indeed. That would be very very nice and it is something that the F/TF has been needing for a long time. When the F first appeared in the marker in VVC form in beggining of 96, it was a very strong car in its class, easily beating or on par withg the z3, slk, mx5. But then as the other put stronger models on the market, there was no response from MG Rover, the supersports always had problems and never appeared in the market.In the Chinese News Thread, there have been a number of references to a TF 1.8T. Its cropped up a number of times over the past few weeks, so I guess we'll have to wait and see.
A TF 1.8T would make a lovely replacement for the 1.8 VVC.
Like most things it would depend on the way its used. a low boost Application would be perfectly feasible seeing as Engine Builders can build you a NA K giving over 200Bhp. a 170hp Turbo wouldnt really put the the engine under that much strain!how long will the k series last under a turbo mod though.
I did hear, ages ago now, that there was talk of using a proton engine....
Correct me if i'm wrong but don't Proton own Lotus now? So it can't be all that badI don't know whether I could live with a "powered by Proton" label. But then again, I do live with "designed & built by rover", so I can't be that fussy.
As the difference between the TF135 and the TF120 was the TF120 did not have the same hotter cams, used the 48 TB, and only having a single air intake pipe on the airbox.Here's the three models of CVT gearbox that ZF make. According to the MGF workshop manual the Steptronic has a VT1-11A gearbox. The 2001 MGF Sales Brochure says that a Steptronic has a maximum torque of 165Nm @3000 rpm and 120Ps (approx 118bhp) @ 5500 rpm. VVC produces 174Nm of torque @ 4500 rpm and 145Ps @ 7000 rpm.
Type VT1 capable of 165 NM
Type CFT 23 for max 250 NM
Type CFT 30 for max 310 NM
Sorry, but for all I know elise and exige people have been talking for a long time about "Very High Power Derivative" heads. So I´ve been reading Roger´s (kiwirog on seloc?) website. And indeed he calls it "motorsport head"There's no such thing as a 'VHPD head' - its correct title is 'The Motorsport Head'.
There are a couple of Elise tuning companies (komotec, ForceFed, etc) who take their air charge trough the side air vent. Although I have to admit the air vents of the elise are much more efficient and easier to route ducting to than an F´s. BBR-GTI have done a conversion on an MGF using air/air. It ran 3 years at 6psi w/o any internal mods, with an air/air IC. But that would not be fool proof of course. I´m aiming at 7psi using water/air. Might not be fool proof as well. It´d better be for a world market. Anyway. Let´s not get this off topic.plus there is no where for an intercooler without major installation re-work. I guess if you ditched the boot, as what would have happened for KV6 then there might be room.
