true... but im hoping to be able to dial everything back from 11 to 5 so that i can use it as a GT-R... GT for road use and R for when i get on a track
with adjustable dampeners and boost pressure valve... and the option of 3 maps on my K-Pro i should have a very versatile car really
true i'll get a fair bit of vibration from my very solid engine mounts but i doubt it will bother me much... i may need to swap springs to something less harsh for road driving... but im sort of attacking my project to make it as track biased as i can, then i can soften it up if it's too much
Talking to Lou at TDi North i should be able to run 3 maps... wastgate or a bit more pressure and appropriate fueling for when weather is tricky
an economy map where the car runs a bit lumpy incase i need to give it to someone other than me to drive (MoT time)
and a 3rd map for track use to see full use of boost and appropriate mapping
they also map the ECU and boost gauge to run more BHP the further through the gears you get.. so that should make the car so much more drivable... even if i was silly enough to plant the throttle and spool up in 1st/2nd and even 3rd i wouldn't have full power
it all sounds very clever and they run road use CTRs with upto 800bhp using this method with no issues
im also swapping my 6th gear for a longer ratio so i can cruise in it (its pointless on a track anyway) the lotus boys do this and it's ment to make the car eat miles as your effectively on tick over (for them) at 75 mph
i might be totaly wrong and i'll have built and un-drivable animal... but people say that allot on forums "it can't be done... it'll be dangerous, it'll kill you and eat babies and war veterans as it drives past"
but they can't back this up and are totally unwilling to try it but happy to tell me with absolute certainty that it can't be done
but at least im going to try... i guess thats where me and you are very similar clive!
and besides... if im wrong i can soon take my turbo set up off... sell it for what i paid for it and go back to N/A form and enjoy a 230bhp totally reliable TF
