Rover 45 - No Power, lumpy idle & stalling.
10K views 24 replies 13 participants last post by  Cap'n ZS
Quiztime! Rover 45 - No Power, lumpy idle & stalling.
A mechanic mate runs his own business, we spent the day working on a customers "headache" Rover 45, I got roped in because his €6000 diagnostic tool wouldn't talk to the car, my Omitec Omiscan came to the rescue!
A lollipop and a bag of sherbet to the person who can diagnose the fault and what was replaced to cure it!
Symptom; lack of power, predominantly from cold although the fault could show up at anytime while driving.
Car starts every time, idles fine, however if you go to drive off there is no power, revs do not increase with pedal being pressed and will stall. If you bring revs up high 3-4k and then move off all is ok.
When the engine is hot the idle becomes lumpy and sounds like a slight misfire.
#19 ·
Can't say if it is the same problem with your car but it certainly was with this one.
What was more embarrassing was the list of items that my mate had changed in the "hope" that it might cure the fault, not to mention the cost.
Diagnostics would have pinpointed the problem if his expensive Brain Bee tool had of worked properly (awful piece of equipment!).
Fuel pump.
Fuel filter.
Coolant sensor.
Cam sensor.
Coil packs.
MAP sensor.
The only re-occurring fault code was P1185, which is the U/S Lambda sensor heating element.
I measured it's resistance and it was open circuit, the diagnostic tool showed it was drawing no current.
The Lambda sensor itself was switching, albeit very erratically, it would stick at 0 volts and 0.8 volt randomly which caused the car to run rich and lean all at the wrong times.
The sensor only works properly at temperatures of 300 deg. C and above, hence the heating element is used to get the sensor working initially and to constantly ensure the sensor is hot enough.
