Reverse gear selection issue (worse than normal)
Mum has just bought an MGF - 1.8VVC. All is good, however it is causing some greif when selecting reverse gear. Now I believe I would be correct in saying it is a Honda PG1 gearbox? - and most of them have a tendancy to occasionaly 'graunch' into reverse? However this seems a lot worse than normal, or what would be considered 'acceptable'. Indeed my Rover 45 1.8 has the same PG1 gearbox - and although it occasionly graunches into reverse, selecting reverse is a doddle compared to the MGF.
Before my mum bought the car, my Uncle adjusted the gear cables - not sure why, I think they where loose. It selects all other gears ok, but not reverse.
Sometimes it crunches when selecting reverse gear, BUT it has indeed gone in ok....you can reverse the car.
Sometimes it crunches when selecting reverse gear, AND has NOT selected ok - it grinds when lifting the clutch up.
Sometimes it does NOT crunch when selecting reverse, and feels like it has gone in normally and silently, but it hasn't as upon lifting the clutch up it grinds (hasn't gone in properly).
Sometimes however it goes in normally - does not crunch when selecting reverse, nor grinds when lifting the clutch up. Hurrah!
I have just tried the MGF, and then tried my Rover 45 with the same gearbox straight afterwoulds, and my 45 selects MUCH MUCH more nicely. I simply canno't believe that all MGF's reverse gear's are this bad.
What is it likely to be....
Clutch?
Gearbox?
Gearbox oil?
Gear selector cables?
Clutch hydraullics?
Clutch?
Gearbox?
Gearbox oil?
Clutch hydraullics?
