Hi Guys we are new to this but need some help.
We have a MGZS 120 51 plate with only 65,000 miles on the clock. After xmas, car started kangarooing and not running properly. There was fuel in and car had been fine until then. We purchased a fault code reader and plugged it in and the faults that came up were PO340 and PO302 which told us it was the Cam Position Sensor. This was changed with no effect!!
Since then we have changed:
ECU
Lambda sensor (front)
Cam position sensor
Wiring loom
Inlet manifold with everything attached (to eliminate the fuel injector)
Battery was changed
Fuel filter
The only wiring left on the car is from the ECU to the ignition.
The cam timing has been checked and that is spot on. The compression test was spot on.
The car was put on a diagnostic machine yesterday and the fault that came up was PO340. Tested the cam sensor and is all working as it should.
My other half is tearing what is left of his hair out and is in danger of getting the hammer out!!!!. Can anyone help please as this car is my pride and joy.
Thank You.
Natalie and Chris
ECU
Cam position sensor
Wiring loom
Battery was changed
Fuel filter
Thank You.
Natalie and Chris
