i've been reading old threads about the kv6 and the differences in the engine between models and tuning the kv6, and it seems like there isnt much support for it.
so far ive read (please correct me if im wrong)
the difference between the zt190 and zs180 is the 190 has a bigger intake cam larger intake pipe and throttle body? and also it has different ecu map. is that all the difference is to make up the 10hp difference?
something about the car being mems3, which mean you can remap the stock ecu.
are the zt190 and zs180 engines interchangeable? as in do the gearbox bolt pattern align up? are the clutches the same?
does anyone know the gear ratios of the zs180 kv6?
does anyone offer a turbo kit for the zs180?
any plug and play aftermarket ecu's available? or is it a case of buying a emerald and custom wiring it in?
other than the thermostat housing and vis rattle, is there any other problems to be had with the kv6?
i plan on buying a zs180 soon to modify, and am trying to find out whats out there for it?
any help is much appreciated.
off to go do some more info digging.
trung
trung
