I use pistons from JDM dyno/UK in my supercharged K S1 Elise. They are designed for a 9:1 CR and std head volume.
They are manufactured by Wössner, but are a JDM dyno exclusive design and only available though Jon.
http://www.jdm-dyno.com/contacts.html
They are about 650 quid, but worth every penny. They are machined on both sides to save weight. I have matched the weight of all four pistons to below 0.05g.
They weight 222g without rings and pins. This is very light. The same Wössenr 12:1 CR pistons wights about 100g more.
He build a turbocharged Elise with 280HP. I spoke with the owner. The car is fast.
I use them with std length chinese steel rods, Mahle motorsport bearing shells and nodular iron liners from Westwood.
CR is further reduced by a 1mm copper shim. CR is about 8.3:1.
The shim is mainly there to save the cylinder head from indentation.
Head is a lightly ported VVC160 head with some chamber work, curtesy of Roger Fabry, a blanking kit and Newman ph2 cams.
Earlier this year I have also upgrade from a Rotrex C30-74 to a C30-94.
Boost went from 0.55bar at 7000 rpm to 0.8bar at 7000 rom and 0.85 bar at 7300 rpm, the rev limiter. Gearbox is a B4BP.
Never been on a dyno. The engine like methanol water injection and gains considerable HP. Not spring, I have to add a bigger pre rad for the charge cooler.
Here is a pull in 5th gear only, but no water injection, on the Autobahn to the limiter (about 143mph).
https://www.youtube.com/watch?v=EJt2Hb0gWZc
Marko
