Car won't get in any gear but 3rd / 4th / Reverse. Not good.
4K views 12 replies 6 participants last post by  DannyR25
I had the misfortune of discovering my car won't get into any gear without some force, and then to make it worse the only gears that do engage are 3rd/4th/Reverse.
Fortunately for me, I only was a couple minutes away from home when I got in my car and attempted to move off. I managed to get it going by using 3rd gear/high revs (Baaaad Danny!) and managed to FORCE [fluke] it into 2nd gear halfway home, I never took it out of second gear for fear I won't get it back in all the way home.
I had felt that the clutch was fairly low when I bought the car in Feb but was told that could be the difference in cars, so I got used to it. I've experienced the gears jamming before - approx last week - but all gears were usable with a bit of push. Today I cannot get it into first gear at all, and only had successfully managed to put it in 2nd gear once.
Now I'm no mechanic, but to me that sounds like an expensive job. Any ideas?
I had the same problem on my old ZR diesel. Turned out the clutch cable had stretched, Replaced it and all was fine.
What was happening was when pressing the clutch pedal the cable wasn't pulling te clutch release arm enough to fully release the clutch. Hence not being able to get it in gear unless the engine was off.
definatly the clutch cable, mine snapped last week. its **** easy to change you just need to unhook it from the clutch pedal (little white clip) and unhook it from the clutch throw arm. when putting it back on clip the clutch pedal end on first, pull the cable tight (needs two people to do this one to make sure the clip doesnt come off and one to pull the cable tight) and then just reattach to the throw arm.
job done
simples!
