Hi Folks,
hope you enjoying the Bank Holiday break.
Just had front suspension wishbone and rear wheel bearing and hub changed for MOT.
Now have ABS kicking IN when breaking at low speed, say just before turning into your drive or moving slowly and stopping for junction, not normal driving speeds. Sounds like a spring pinging from front accompanied with the ABS judder through break pedal.
I believe there is a metal magnetic ring as part of the rear wheel bearing assembly which is used as part of the ABS set up, could it be garage has changed wheel bearing with wrong part? Garage claiming nothing they have done. Any other sensors front or rear that could have been dislodged or damaged?
Any advice would be much appreciated.
Car showed no signs of any issues prior to repair and have no dash board warning lights on. Car breaks fine too except as mentioned when low speed breaking. Oh yes and steering wheel now at 11 o'clock when driving straight, yep seems have found some real garage cowboys!!! Advice from forum is tracking for latter taking into account work had done, so tracking being done on Tuesday by garage that did original work, god help me!!
Thanks in anticipation.
Steve
Steve
