The final nail in Triumph's coffin.
The dolomite engines was the Stag's but a cut down version. The Dolly engine came first though...Londonbabe said:Saab used the straight 4 - based on the Dolomite engine.
Their much earlier V4 was Ford's and straight out of a Transit van.
It was a foolish decision not to simply drop the Rover V8 in there in the first place, like so many people did after their Triumph V8 engines died.MGROVERnut said:It was a foolish decision not to fix the Triumph V8. In fact most of the cooling issues were caused by a poor casting process at the time (according to the guy who designed it).
If they had invested a little more time and money to cure the overheating problems then it would have been a superb engine. It was a lot smoother and more powerful than the Buick V8 and streets ahead of the Ford V6 that was also used as a replacement. You'll probabaly find that those Stags that still have the original Triumph V8 command better prices than those with the Buick or Ford lump.Sunbeam Man said:Yeh, it was a V8, my mistake. It just seemed strange that it was just left and never entertained again in any way. What would have happened to all the old Triumph engine and body casting at the time of closure in the early 80's.
I've walked past the building that the production line is supposedly in. There is certainly something in there but the windows have got thirty years of grime on them and you can't see what it is...podders said:...the last I heard was there were rumours the tooling was still in the building it was made in- they switched off the lights, locked the door and walked away and its still there 30 years later.
Okay I know sniffpetrol is a bit of fun, but they have shown a lot of ignorance in that article. As a Stag owner and a member of the Triumph Stag Owners Club I have to remind them that the Stag is one of the few classics where vast numbers of the original cars have survived. The cooling issue was the only problem of any significance. Yes the way it was built was as bad as anything else BMC made but it is fundamentally a good car. Stags with Rover V8's are not considered good car (contary to what most people think). The Stag was not designed for such a heavy engine. As said earlier if BL had fixed the cooling issue than the Triumph V8 would have been a far superior engine to the Rover V8!david_r_bates said:
One thing that they're absolutely right about is that the Stag is one of the best looking cars ever.MGROVERnut said:Okay I know sniffpetrol is a bit of fun, but they have shown a lot of ignorance in that article.
Are you for real?MGROVERnut said:That's interesting because if Nanjing were to cure the cooling issue (Hart racing could help with that) then the Triumph V8 may be up to date enough to go into a new car with only a few mods. Saab only stoped using the V4 version a few years ago.......
Where abouts was the Stag engine (and all of the other Triumph engines) built?boxwellm said:I've walked past the building that the production line is supposedly in. There is certainly something in there but the windows have got thirty years of grime on them and you can't see what it is...
Unfortunately, you can't go into that building any more. It's falling apart with the roof caving in and the creaking noise from opening the door would probably be all that's needed to make the whole thing collapse.
I certainly didn't dare sneeze within fifty yards of the building...
Well yes. MGR does not require that many V8 engines so designing and developing a new V8 would be a waste of time and money. Buying in the Ford V8 again is possible but that's not a very good engine really if were honest. I accept the Triumph V8 is old but if and it's a big if you could find a way through emmisions testing then it would be fine even by today's standards. I mean the Stag engine is still newer than the Buick/ Rover V8 and Land Rover only just stopped using that. The Triumph V8 does lack the potential capacity of the Rover V8 but it's a LOT more modern and lighter. So for a few cars it may be worth it....especially in the Chinese market.Mr_Censored said:Are you for real?
Surely the SD1 line went to India? It became a Standard!Bob S said:I heard somewhere that much of the SD1 line is still in a vacant building at Solihull? Doubt thats true though.
And before that it was built for 5 years at Cowley. I'd bet the entire Solihull production line moved there in 1981.Lord Minty said:Surely the SD1 line went to India? It became a Standard!
