Hi guys, Noticed that turning the map booster up on the tu1, make the power cutting happen a lot more often.
Also its now happening in 3rd and 4th as well as 5th. The car is fine for normal driving, but its extremely irritating when im trying to overtake something, or get somewhere in a hurry.
Perhaps it could be a defective map sensor? the only other things im thinking of are the fuel pump or injectors.... i can get the injectors tested for ÂŁ12 so i will do that, however fuel pump testing is ÂŁ55, and im just thinking it may be cheaper to obtain a pump from a scrap yard.
Any thoughts?
Just to remind you, it makes lots of grey/black smoke and the engine note gets a lot louder and more rough when the power cut happens
Also the boost has been reduced so it hits a maximum of 19psi, all hoses have been checked, i made a new gasket for the charge pipe, and there is no shaft play in the turbo, although its still letting a little oil past the seals.
Any thoughts?
