T16 turbo
3.4K views 19 replies 13 participants last post by  Debs(Nitrous)TF
Has anyone attempted or done this conversion and what problems did you come across and was the end result worth it?
I was thinking of doing it but relocationg the turbo to the front and having the exhaust exit out of the side either in front of the drivers wheel or behind it, reducing the temps in the engine compartment. I saw a company in the USA, remote mounting turbos with virtually no lag and more BHP over a standard Turbo sometimes 30BHP more due to Heat reduction.
#4 ·
funnily enough I read an article recently where the turbo was mounted basically where the backbox was, it was on a 205 or something. The piping back to the inlet acted as an intercooler and apparently it worked very well.
Is it neccesary to fit a rover engine? i'm sure there are other engines which are lighter which may fit, obviously you would need to be one heck of an engineer but i'm sure its possible.
Forced induction is the only way to make these cars really fast in my opinion.
There was talk last of a T16 turbo conversion but nothing has been seen of it yet.
Personally if I was looking for an alternative power plant I would be looking at KV6, there may even be a kit produced next year.[/quot
who maybe producing a kit? reckon V6 power would feel lovely especially with a tweak here and there could have the torque we're craving!
#14 ·
so is cooling the only reason the 160 BHP 1.8T out of the rover 75 wouldn't work in the F/TF? The torque curve is vastly superior and even with a mild re-map would give probably 180BHP and lots more torque. If cooling is the only barrier then I'm sure it would be an easier transplant than any other engine.
#19 · (Edited)
The Rover 1.8T manifold fits in TF engine bay, but it is a tight fit as can be expected. Water hoses need to be rerouted to accomodate compressor housing and air filter, but not insurmountable issue.
An extra heat shield or two should keep heat away from the fuel tank, which sits behind a shield as well as a body pannel where the turbo is located. BBR marketed a turbo kit with a manifold in the same size as the 1.8T manifold, which was a log style manifold which does not look like a very efficient design, so heat buildup under normal conditions could be expected. I opted for a tubular manifold as shown to the left, with the hope that the decent diameter tubes and equal length will be efficient, which hopefully equates to a cooler setup at normal operating conditions.
