SDI fueling problem
1.7K views 32 replies 8 participants last post by  Dr Dave
Sorry for posting this up again but i still have this problem opf fueling level being cut after 11 seconds on the accelrator.
from suggestions and rover diagnostics hookup i have...
Bled the fuel system to try and remove any air
Replaced the MAF sensor (Rover's solution)
Replaced the MAP sensor
Fitted a boost guage to check this
am running out of things to check/change now anyone got any ideas as i have priced up replacing the diesel injection pump :(
andy
after 11 seconds on the accelerator the check engine lgith comes on and the level of fueling drops basically. As the fueling drops i get a drop in boost and boost goes up albeit very slowly so its not losing boost thats the problem as it does gain boost.
had it up to rover paid ÂŁ65 for diagnostics to be told it was my maf sensor, I've tried 3 Maf's in my car including phils(ultimateracer) and to no avail.
Thanks for that.
I would now check the boost pressure sensor, the wiring connector points upwards and collects water (Great design there guys...) and corrodes like a rusty nail.
The resulting corrosion causes a loss of signal to the ECU and hence loss of performance.
Pull the plug off and tell me what you see..
#15 ·
There is a place that does diesel stuff in rotherham, but I can't for the life of me remember what it is called. (near masbrough spares). The old chap there seemed to be very helpful, but I guess if it is an electrical problem then they might not be much use.
Have you measured the boost pressure with an accurate gauge, as if the ECU sees an overboost situation it will go and sulk.
I'm not surprised the MAF sensor didn't fix it - it only controls the EGR valve - even if unplugged - it doesnt turn on the MIL. Doesn't even turn it on in both my 45s and can actually improve low down power at the expense of on boost power.
The only thing which turned the mil on on my 45 was the throttle position sensor, although I can't see it being the TPS, but:-
Do you have to use full throttle before it cuts the fuel, or will it do it on say 80% throttle?
By the way, has it been chipped?
Otherwise, its probably a faulty fuel servo position sensor in the pump.
(indicates to the ecu the fuel quantity injected by measuring the position of the actuator which controls the stroke of the high pressure pistons) though the Rover diagnostics should have picked this up (possibly).
Before you change the pump, check the condition of the contacts in the crankshaft position sensor and its plug.
Have you checked ALL the engine management connectors - incl the one on the pump, and from no1 injector?
The check engine light comes on...but its red this tell you anything?
any amount of throttle causes the problem, it also does it when i hit the rev limiter as a i found out today.
no its not ben chipped
The car has had prvios fault with no1 injector timing according to the fault code but it is recorded as a previous fault not a current one. I've chacke the connections but im not really an electrician, all appear t be ok but i could be wrong.
will take a look at the crankshaft sensor whe i can find out where it is.
ty all
andy
#19 ·
ty all
andy
The crankshaft sensor is to the rear of the flywheel - it senses holes in it.
Is the fault rpm related?
IE if you floor the throttle at 1500-1800rpm in 5th on a hill (to stop the revs rising quickly) does it still cut the fuel?
(This would also eliminate the map sensor as not much boost is would be produced at those revs)
Try unplugging the no1 injector cable and see whether its better or worse.
Think you've got the same problem I had with my old 220sdi.
Accelerating hard in 3rd+ it would stop accelerating at about 3k revs for a few seconds, and then carry on again, only slightly slower.
Havent got an answer for you, but I took it to the garage plenty of times, and no-one knew what the issue was. Although it did only start when I changed into 3rd accidently going quite quick, and the revs went to about 7k very briefly. Perhaps that broke it. I know the rev limited never worked again.
AndBurG said:
fuel pump??? :
andy
There's only the pump or ecu left!
Is there a tcking/buzzing noise coming from the pump when you turn on the ignition? (Advance solenoid on the underside) There should be.
I'd try a pump from a breakers first. Its unlikely it would show the same rare fault even if it was not perfect.
If you changed the ecu you have to have it coded to the alarm unless you changed them as a pair from the same vehicle, then the remote might need recoded as well (Major?)
