Hi,
Since a few weeks ago, my car (Rover 25 TD) has a strange issue.
Sometimes it looses power. But it´s not a suddently thing that changes when driving. It´s a thing that remains since i start the car on and off.. I mean, sometimes, i start the car on, everything if fine, i drive it with all the power it should have, until i turn it off.. Other times, i turn it on, and i felt it has not the power it should have and the situation continues until i shut down the car..
At least it´s the feeling i have.
I hope u understand what i mean. English isn´t my main language.
For example, yesterday, i´ve started the car, and i noticed immediately the car wasn´t pull fine.. I drove about 10 miles and not a change.. I even tried to shut down/on the car when moving and no change.
Then i park for about two hours, and i drove again, everything was fine, the car was pulling ok.
Question isn´t related with car being warmed up or not.
What i feel:
On normal driving, at about 1300/1400RPM i feel the turbo start kicking in, and then at about 1900/2000RPM it kicks in real hard..
When this happens, i feel the turbo kicking in at 1300/1400RPM but then nothing happens, feel nothing at 2000RPM. I don´t feel the "second kick in". When this happens the RPM don´t past the 3800/3900RPM. When they reach +- 3600/3700RPM the car acceleration gets very very slow, and then it stops at 3800/3900RPM.
I have a scangauge and it reads 15.5PSI on both situations. Don´t know if it´s accurate or not but it´s strange the turbo has the same pressure even if i don´t "feel it".
I´ve changed the MAF for a spare one i have, the result is the same.
Don´t know if it´s related or not, but lately i notice the fuel pump is leaking a bit and the car sometimes smokes (not so much) on hard acceleration (black smoke). Another thing that happens, when the engine is cold, it has "hesitations" (like the engine was turning off) for a brief moments (like half of a second).
In the past i had a situation with some similar symptoms (lack of power) and less RPM and it was one of injectores (the main one with the wire), but on that case, the car never pulls fine.. And it reaches exactly 4000RPM and then it was like it hits a wall.
Any suggestion?
What i feel:
Any suggestion?
