rover 200 engine noise
1.3K views 7 replies 6 participants last post by  cjmillsnun
Hi, I have a 99 rover 200 1.6 , ive noticed recently my engine sounds quite rough in idle, but when i put the clutch down the rough sound stops. Is this normal? or is there anything I can do to fix the problem?
THanks Alot
Dave
Well a thrust bearing is cheaper than a new gearbox (the only other possibilty)...replace with three piece clutch assembly clutch plate,diaphragm and thrust bearing .........then see what happens.
worn thrust bearings often rattle on idle.......and make a whining noise ..and sometimes a shriek when clutch pedal is depressed.
all the best..mark
