Removing interior tailgate panel on a ZR
3.1K views 9 replies 4 participants last post by  Steve Taylor
I'm going to fit the tailgate part of my remote central locking bits tomorrow, but I can't seem to remove interior panel which covers the lock. I've removed the 2 screws and that has loosened that park but it's still firmly held on and I can't see how to get it off.
Some help required please.
Err, bit of a problem :(
We fitted the tailgate motor, and the tailgate loom and it doesn't work :(
We quickly found out that the pink and orange wires which operate the motor are not present on the loom which leaves the tailgate and heads down into the boot. They are present on the loom at the bottom though, so when Dr Dave sold me the bits he forgot I needed an extra loom. On the label it's called "tailgate sub" so I guess I need one of these as well :( Looks tricky to fit as well :(
I can see both ends of it, but as it's very difficult to get the ends off the plugs I'll contact Richardsons and get a new loom.
I've just properly fitted it to the driver's side door :D The supplied loom I did not even need, and even if I did it would have been no use as it didn't have a connection for the tweeter.
It was very difficult to fit, but it's done now and works fine on that door.
:D
Yeah, I'm an Underboss on OcUK
Ironically I had my tailgate panel off today to fix the problem I had with my boot central locking.
It turned out that the orange wire had broken (at the point where it feeds up into the taligate hinge cavity under the right hand side rubber bung)
If was half tempted to take photos of the repair job but decided against it.
I wish I had done now as it may have helped you out! :(
