ok usually i will happily advise someone no question about it.
but seriously, there are countless threads about explaining how to do it, plus its really not that difficult and i think everyone should be made to buy a haynes manual anyway, they explain how to get to nearly everything you will ever need to.
i dont target that rant at you djalien10, its just my general opinion.
painting your drums...
jack the car up at the specified point along the sill
remove the wheel
remove the drum (2 screws)
rub down with an abrasive wet and dry paper (80) or a wire brush
remove excess rust by blowing and ensure the drum is clean
paint with high temperate paint (whatever colour) 2 coats
painting your calipers...
jack the car up under the sump
remove the wheel
leave the caliper on, as it isn't worth bleeding the brakes
clean it up in the same way as you would drums but on the car
and paint with high temp paint avoiding anything that isn't part of the caliper, i.e bleed nipple and pads
high temp paint takes hours to dry, when it is you can put the wheels back on and remove the jack
jobs a good'un
