Rear Trailing Arm Bushes - Removal
19K views 33 replies 13 participants last post by  thescamper
Now i have discovered the secret of my " squeaking back end " + the occasional knock, its the RTA bushes.
Now, besides beating the crap out of them to try and get them out, is there a civilised way of doing this, that doesnt involve costly garages and the groaning of my never never never never card .....
Having done the front lower bushes last weekend, which involved much bashing, i am trying to avoid a repeat.
i mark a line through the bush centre line and the front track adjustment bolt, then i remove the tracking bolt, pull the arm down with my left hand and beat seven shades of **** out of the bush until it pops out, to fit the new bush line up the bush mounting holes/centre line with the mark you made then beat it back in with attention being paid to hit the outside of bush evenly, once its in to the correct depth refit the front part of the arm and align the trackning bolt with the mark you made, useally takes 15 mins on a ramp
I've just spent a few hours under-sealing the 45. It looks like my late 2001 45 came with no under-seal from the factory. Anyway , whilst I was slapping on the Tetroseal , I noticed that the rear bushes were showing some signs of deterioration.
I gather all that is required to change the bush is the removal of the two 15mm bolts securing the bush and the handbrake bracket? Can the arm be pulled down by hand? and then wedged with a suitable piece of wood.
I'm not exactly sure what to mark before removing the old bush.
Bushes
Am new to 45 ownership and my bushes are showing signs needing replacement is the picture correct, I have read the other thread linked to above and am not sure that the bushes are a cheap home job due to alignment issues.
So I suppose what I am really asking is do I just undo the three bolts shown above beat two shades of sh** out of the bushes and bolt it all back together job done.
TVM
Steve
The correct way to do it is to remove the swinging arm from the car and press it out using MGR tools 18G 1733/1 and 18G 1733/2.
However, we all know that is not always possible, but my mind boggles at the image of somebody whelting allsorts of $%^& out of the swinging arm whilst laying on their back under a car supported on axle stands.
It must be possible to do it in situ. using something like a bit of tubing, of suitable size (just smaller than the O/dia. of the bush) and a couple of bits of plate and a couple of decent size longish studs to apply the pressure.
I no longer have the facility to make anything up now, but would have made something like that.
#23 ·
we used to have speed comps with these at caffyns due to the immense book time they gave and charged the customers for and theres a captive bolt on the front mount the two ta bush bolts and a lil h.brake cable bolt to mark up and remove pull the arm down and wedge a bit of wood between it and the body to stop it moving then knock it from the underside out then the new one taper side in from the outside keeping it level of course then bolt it back up...easier on a two post lift and sodding hard on the ground but should take no more then 30 mins a side (with a two post lift we had them both done in abt 16mins flat and they still charged the 8hours book time to the customers for removing the whole arm and pressing them in/out)
#27 ·
Thanks for that. I am giving it a crack during week. I have been WDing relevent parts 'n' bolts for a few days now.
Looking at the job with car on jack, once the front bolt and bush bolts are removed would it gain having a second jack raise the Arm by jacking under the shock and sort of close the shock/spring raise the hub etc. I was trying to reason if this would help lower the front end of the arm to get at the bush.
If the bush won't drift out i am working on a universal bush press arragement, which i will be testing.
#31 · (Edited)
Please to take care to include a couple of axle stands for your safety.
#28 ·
Once the trailing arm has been freed, it's easy enough to lever it down with a bar and then brace it with something.
After looking at the extortionate prices for Honda trailing arm bush tools (ÂŁ145 is the cheapest I've found) I think I'd be better off making my own with a 2-legged puller and a big socket or something for about ÂŁ20 lol.
#34 ·
Job Done
As it says Job done, What a t*** of a job, took me 2 hours to do the first one coz I couldn't get the bolt (No8) undone so had to mark and undo the tracking bolt.
Bolt No8 came undone on the second and it took 20 minutes to do.
If I had one piece of advice have plenty of various size bits of wood (at least some 4*2 and I used a bit of 3" square) and a couple of bloody great levers and the best hammer to use i found was a 2lb ball pein hammer.
Enjoying a well earned cider now!!!!
Oh and yes its made a world of difference to the car no skipping round corners and no more squirming under hard braking.
