Hi guys,
anyone help with the offset/ thickness dimensions of the ZR/ZS 282mm front discs?
The idea is for a brake conversion for an MGF. The PCD is of course different, but either the existing stud holes can be slotted, or new holes drilled to the correct 95.25mm.
The MGF discs have a 44mm offset, 22mm thick and have a 66mm centre hole.
Interestingly, BMW Mini Cooper S discs have the correct offset and thickness, but are 272mm in diameter, so a modest advantage is to be had with MG discs!
If anyone happens to have the relevant information pertaining to the rear discs of these cars, that'd would be really useful too!
Cheers!
Cheers!
