221 - 240 of 332 Posts
Hi seems this seems to be the thread to thank Paul .Technozen.
It was well worth the journey down to sort my streetwise electrical faults.
He is brilliant. I met him at his house and he was able to do lots of jobs ,Changed all relays, programmed new fobs changed body and battery on my old fob. reset eka code, waterproofed and refitted the unit
So now I have working driver electric window and intermittent wipers .
plus lots or useful advice about common diesel faults.
Basically, he is an expert in this field and gives absolute attention to detail.
Thanks a million.Jason
technozen..... can I please ask you for some advice :) I have a 53plate rover 25..battery went flat, fob wouldn't open the doors either, had an idiot (I think) jump start her which didn't work, but he did manage to make my horn beep every time he attached one of the jump leads to my battery??), so took the battery off and charged it (for 10hrs on high, 12v...was this long enough for a completely flat battery??). however, when I (well a friend as I have no knowledge of cars other than how to drive) put the battery back on, the fob still wont unlock the doors, unlocked it with the key and when I went to start the car (turned key once) all the normal dash lights came on but also the hazard lights came on, when I went to turn the key to start her there was nothing at all...is this a fob, immobilizer problem??
have changed the battery in both key fobs today, but they still wont open or lock the doors...when I try to start the car with the key (using the key to open the car door) the lights on dash board (parking break, oil one battery and sas lights all come on) and aren't dimming at all (except the sas light which goes out), and the battery light is getting brighter when I attempt to start the car and for a split second the immobiliser light flashes (but at all other times the immobiliser light isn't working???? I have tried both key fobs and neither of them are working??? any ideas what this could be please and thanks
You can use technozen's (Paul) generous offer, remove your unit and send it to him otherwise it would cost you about ÂŁ35 to get it programmed-buying another SCU is a bit extreme.
wiper issues
Hi Paul,
I've got an annoying fault with the intermittant wipers. Work fine on normal and fast, but on intermittant they take about 10 or so seconds to start. Not good when its raining. The missus hates it. I can hear the relay clicking, so i'm guessing the relay is lazy, or has corroded contacts.
I'm guessing this could also be a sign of water ingress but I won't know till I pull it out (its an 05 ZR with air con so not looking forward to it).
I'm quite happy changing relays/ics etc myself, but one of the fobs has stopped working (i'm guessing the only fix is replacing it), might as well kill two birds with one stone if I bother pulling it out.
what is your turn around time if I posted the BCU?
Alternatively, I remember many moons ago you used to travel to NI, don't suppose you're heading up to the north west any time this summer? :)
Danny
I did consider that, but they work fine on 'flick wipe'. Do these not basically run on the same circuit in the motor, so I'd theoretically have problems with both if so.
I'll have a look tomorrow
Hi Guys,
Please may I ask for a little assistance. Ill bullet point to make it brief:
*Dead Battery - Replaced
***** poor job by me in replacing this. The alarm went crackers so I pulled the positive battery connector off (I get the idiot and try hard trophy).
The SCU now seems a little screwed. The car has no interior light, rear wiper, central locking, Immob LED and a few other internal bits and bobs don't work. Dash all illuminates OK but needless to say, the car only runs for 2-3 seconds before it cuts out.
I have tried disconnecting the battery, removing fuse 5 in the engine bay, reconnecting the battery and then replacing the fuse to reset the SCU. No go.
I have also tested the continuity of the main fuse, this is OK.
Any advice going forward gentlemen?
Thanks in advance,
K
Discussion starter · #232 ·
The SCU has an internal fault which is stopping it from powering up correctly, I can repair this, PM me for a price etc.
Hi all!
MG ZR (55 plate) driver window went down and won't go back up. Need it fixed, I managed to get it closed by putting 12v straight into the motor, can you help please technozen? Need it doing so I can sell the car!
Thanks in advance.
Cheers for the many replies :L bought new relays from yourself so hopefully will solve it!
ok i had the issue with the horn and drivers window i changed the relays in the unit as per instructions but i now have the right indicator flashing when ignition turned on is there a known fault ??? of have i done something wrong
pektron scu/bcu streetwise 04 1.4i facelift
Hello technozen
I hope you dont mind in me contacting you regarding our fault in our streetwise.
there is a couple of problems :-
first one - horn would not turn off, pulled fuse out, checked buttons and horn itself all working correctly. As the horn has no fuse the fog lights are not working. M.o.t due soon....
second - electric window drivers side (one touch) not working as with interior clock stopped at the same time, again checked switch and motor,.
ive asked a few people within the car service departments they all say the same its going to cost money looking for the problem...
as ive read all the problems other users have ,I have come to agree that this is the problem with relays.
please could you help we use this car everyday and still use this with no horn, no window (nightmare) etc ,
thankyou in advance for any help
peter
SCU - interior light on all of the time
Hi Technozen,
I have read you posting on the SCU's, very informative and useful.
I have an issue with mine as the interior light remains on all of the time, hence flattening battery. I have disconnected all of the interior lights, footwell, mirror, boot, and apart from being dark at night all other functions operate normally.
I am presuming the drive transistor (I presume it is switched to ground) has failed?
For me to get at it and fix by soldering a new transistor I was wondering what happens when I remove the SCU from the car and start messing with it regarding the key fob data/code and once replaced back into the car if the key fob will work without all of the coding of fob/extracting of SCU code etc.
I feel without doing the back up I am at risk of the unit deciding the fob is no longer valid.
Your thoughts on this and the output drive circuit configuration / circuit diagram would be of use.
Steve
Just a quick thank you to Technozen for providing a new relay and all the information that helped me tracing my central locking malfunction to the SCU.
(In my case, car was locking fine but no unlock whatsoever from both the doors, girlfriend has been hopping on board from the driver side for weeks).
hi i wonder if you could help i have a facelift mg zr and recently my battery went flat i charged my battery and reconnected it i then had hazards flashing no fobs would work and it wouldn't turn over and there was a constant buzzing so took the power off then reconnected it now as soon as you touch the terminals on the battery the alarm sounds and will not turn off can you help
Discussion starter · #240 ·
It's either one of two possible problems...
The flat battery has corrupted the configuration data stored in the SCU memory.
Worst case it would mean new fob(s), security matching the SCU to ECU and reconfigure the various options.
An internal power supply fault in the SCU has appeared (usually only happens after power is reconnected), this is relatively easy to fix.
Send me a PM if you want to discuss costs, options etc.
