Hi All,
I'm new to the forum and have just bought a 2001 model year mgf with 43k miles on the clock. Sorry to trouble everyone with a overheating problem but hopefully you'll be able to give me some pointers. I picked up the car Saturday and drove home 125 miles with no real issues (it was about 21 degrees and intermittent rain). At one point the gauge crept up slightly so I put the heater on for a bit and the gauge dropped to normal. Since then the weather has warmed and after about 20 minutes normal driving the coolant and oil temps go way up. Putting the heater on controls it just above half on the gauge. The car has had a uprated HG about 6 years ago but has only done about 2k since. Both fans work as does the heater and there's no coolant loss as far as I can tell. At idle with the cap off I can see the fluid return working in the expansion tank. I've opened the rad bleed and front bulkhead bleed and get fluid although the bleed screw under the distributor is seized. Does it sound like an air lock issue ? I'm planning on draining and flushing and changing the stat. Is there anything else I should do. Any advice on the best way the change the thermostat would be welcome. It looks a bit of a pain to do? Again sorry to ask another overheating question but the more I read the more confused I'm getting.
