I don't think it's been answered yet: Which one can yield more power providing there's enough air/ decent map etc.
Just weighing up my options.......
Yup,atm i have no coolant or clutch issues,everythings fine and i just did a full service.I'm running with a remap giving good performance and just a bit of smoke,so guess i'm at the limit fuel wise with the mods i have.I also have a new mod i want to test on the air side...double open cone...i want to see if it makes any difference performance wise.To the rollers with full power? Hmm, this could be interesting.
On a std ZR/25 113 version wingy spec produce more then SDI's:I'd imagine they would produce more power than SDi's, but wouldn't want to risk high EGT's etc.
Dave
Now I've a question for the techheads - has anyone tried having their wingy injectors re-calibrated to a higher break pressure (increase atomization) and have their timing mapped recalibrated to suit?
Should in theory be able to push more fuel for the same quantity of air that way. Higher break pressure makes a finer mist, as the pump has to over-ride this, the mist travels further, droplets are smaller, because of this they burn faster (and it's Bosch telling us that so I'd trust the theory) and basically make better use of air, especially at the top end of the rev rnage.
Dakta, yes I looked into getting some wingy nozzels fitted to sdi injectors second stages. Wingy was very much against the idea. It was very much his way or the highway. I choose the highway, built the hyrbid injectors and still have a car that works.
Well Reading everything above you've confused me slightly in your thinking between you.My way was always was the highwayoccasionally you pass and wave at assosciates but each has his own lane and turnoff.
I think it would be a worthy experiment, but the wingy nozzles would have to be a must to ensure a decent quantity can be delivered.
As I have a spare set of wriggly injectors I wonder where I could have them done (if you change the first stage it changes the second, as the second stage is cumulative with the first as far as spring pressure goes) and not all diesel specialists can do that. Not something I'd do myself as the shims come in sizes that really need a microscope to detect, so wants a proper bosch supplier etc to set up the BP's.
Your right there John,no advanced timing at all if i remember correctly.I suspect our maps are very much different. I dont think Roberto is using an advanced timing map, as this would really shoot up the low end torque.
My way was always was the highwayDakta, yes I looked into getting some wingy nozzels fitted to sdi injectors second stages. Wingy was very much against the idea. It was very much his way or the highway. I choose the highway, built the hyrbid injectors and still have a car that works.
simple thing to remember that will make it clearer is a fliud is incompressable. with a higher brake pressure two things can happen, the same quantity gets injected at a higher pressure, or the pump breaks! Kris knows all about this hey matey!Take two injectors, both identical but different break pressures. The one with the higher break pressure will in a lot of cases deliver more, simply because it's duration of being open will be spent with the fluid moving at a higher pressure. There is an arguement against this. Another myth eh?
How did you figure that out Dan?Why was the rolling road done in 5th gear?
Don't know about the ECU map,but the maf is almost new.I'm afraid the head gasket might have something to do with this unfortunately... :-(The losses seem a little high too if I'm reading the numbers right .
The lower than expected torque could be due to all sorts of things, the ECU map and the MAF sensor would be the prime two suspects if everything else is "normal"
Wasn't it Diesel Bob who did the injectors anyway via Wingy that is, would email Bob tbh and see what he says.Can any 1 tell me how to get wingy injectors or how can i get old of him thanx
