MGF - 2001 - Ran out of petrol and now won't restart!
8.1K views 45 replies 17 participants last post by  t0m4ever
HELP! The 2001 MGF I drive ran out of petrol earlier today and following two visits to the petrol station and £10.00 of petrol later simply refuses to restart. The car did initially start but idled erractically at low revs but now refuses to start full stop. I figured maybe a blockage had been caused by dirt being picked up from the tank so I put some fuel cleaner in the system but this has done no good at all. I have a mechanic coming on Thursday morning to take a look at the car but if you could suggest any practical measures I could take between now and then to perhaps save myself a few quid I would be most grateful. Thanks in advance John
:eek:verkill::twak::twak2:
I believe someone else got into trouble on nother forum for making a comment like that ;) :lol:
Yeah, around 8-10 pounds fomr a motor place (not Halfrauds). I dont think you can clean it.
As long as you know how to open your access panel it is a piece of wee.
No.
Normally when you run out, all the crap at the botom of the fuel tank which normally doesnt get disturbed gets pumped into the fuiel filter so it probably will need changed.
I dunno why the pump isnt priming though? Fuse?
"I dunno why the pump isnt priming though? Fuse?" You've lost me with the priming thing! Where would I locate the fusebox? You can tell I only bought the car yesterday can't you! Thanks for all your help - much appreciated.
Sorry, I htink I have mixed up with another fuel type question thread :lol:
That person said the pump was not priming. BAsically when you turn to no.2 , you should hear the pump "priming"?.
Sorry, if your makes that noise, then I would go with filter first
#15 ·
Nope,
Just keep cranking the engine with the throttle pedal half down and it should start.
The other thought is that the car is now flooded.
May be worth disconnecting the inertia switch to disable the fuel pump., and turn the car over for a few times. If the car starts, then dies, then you can reconnect the inertia switch and she should start normally
The car now has £15 worth of petrol in it and it still wont start! I've also replaced the filter this morning (£9.28 in case anybody was wondering) and while i'm sure it has done some good it hasnt fixed the problem. Anybody care to tell me where I can find this inertia/fuel cut off switch? Im a bit thick with cars so nice and clear directions please!
#36 ·
inertia switch location
the switch is located passenger side under glove box behind wiring loom
you have to remove glove box to get to it
thats if you have a rover 75
Open the boot...remove the engine bay cover (with flaps not the access panel).... look to the left just under where the aeirial goes into the car, you should see a black button stuck to the side of the car just under where the hinges are ..it may be brown becuase of dirt. Hold on , I have a pic on my webspace somewhere
Although unless you had a crash , why would it need resetting? :dunno:
So when you say its better, what exactly is happening?
An earlier poster had suggested disconnecting the switch, turning the engine over and then reconnecting the switch to solve the problem. Am I right in thinking that when you turn the ignition you should hear a 'buzz' as the pump readies itself because if that is so, it isn't happening to me!
By way of an update I wasn't able to sort the car myself and the auto electrician who came out this morning has identified that my fuel pump needs replacing. The quote I have received is £180.00 for a new one, is this reasonable or can I expect to get it cheaper?
#29 ·
Yeah, £184.44 is about right, I nearly had a bloody heart attack. Scrapyard is a decent idea but I can't imagine there are too many MGF's to be found. Still, I got the car for a song so it's money well spent. I'm so impressed by the spirit on the forum, it's a real community - thanks very much to everyone who has lent a hand I hope I can return the favour in years to come. Cheers, John
#33 ·
Are you sure it is the pump? Reason I ask is I had a similar issue with my pump not working and it proved to be the connector. I read somewhere that heat from the engine bay can cause expansion of the connector over time which results in loose pins in it.
Whilst not wishing to cast aspertions on your auto electrician, it may well be worth double checking the connector is making good contact - perhaps applying some switch or contact cleaner. It is a little difficult to access the fuel pump but it can be done (for testing this anyway) without removing the t-bar, by removing just 3 bolts and sliding the access panel to the side.
I actually had the nice AA man do mine, ironically at their former headquarters in Windsor where I was visiting at the time. It took him about 40 minutes in all, including checking all the fuses etc..
