Hello,
I am an ex-longbridge engineer - I actually was part of the team developing the Mems 3 calibration for TF, and Z models including the 1.8 turbo.
In reply to some points in the thread - Mems does not use a MAF input, relying on a 'speed density' mass air flow conversion from the MAP sensor which also provides an intake temp input.
Regarding knock sensors - these were tried in development but general noise from the block made accurate isolation of a knock event too unreliable - so no knock sensing in production..
Another point to clarify is that Mems does not have a limp home strategy - the only torque limitation is a large retard offset to reduce power above 150 degrees oil temp... Your running issues are down to elementary combustion problems, probably due to component incompatibilty with the ECU.
Mems software includes maps covering injector flow rate/volumetric efficiency and target lambda as a fundamental part in system fuelling calculations. Without accurate compensation your component additions will mean AFR and ignition values way out of control..
Remember the K series turbo involves lower compression, wider range tmap sensor and modulated wastegate control etc. Not to mention a fully revised ECU cal.
Running a VVC with a turbo is another novelty - its possible the wider overlap at higher loads is also giving combustion problems as boost builds.
I now run a support service for Mems issues which includes the ability to rewrite the calibration, for instance to provide the wider range of man pressure inputs needed for a turbo.
However in your case the list of cal areas to be amended would be pretty significant and would also be best developed on a test bed..
For a simpler route for interested parties - I have just begun to investigate the possibilities in offering a calibration for fitment of the K 1.8 turbo in the TF/ZR models which may be the simplest route to turbocharging...Ill keep you posted.
In the meantime have a look at
www.zandf-tuning.co.uk
for more info on the service.
