I noticed today that my glovebox is broken at one side. I was going to replace it with one i saw in the scrappy. How do you remove them ?
S Southside 3,847 posts · Joined 2005 Add to quote Only show this user #2 · Oct 10, 2009 2 8mm bolts underneath on the hinges then its off.
Stu 53,503 posts · Joined 2002 Add to quote Only show this user #3 · Oct 10, 2009 Yep, 2 minute job.
B Bionic 4,892 posts · Joined 2008 Add to quote Only show this user #9 · Oct 10, 2009 thats an over statement lol unless you count emptying it if there is alot of stuff in there
R R25Silver Discussion starter 3,481 posts · Joined 2008 Add to quote Only show this user #4 · Oct 10, 2009 Thanks guys. Will get it sorted out in the next few days
M misterreliable 2,190 posts · Joined 2004 Add to quote Only show this user #5 · Oct 10, 2009 Leaving the glovebox closed whilst removing the 2 x 8mm bolts also makes it easier.
D Dr.Buck 12,502 posts · Joined 2007 Add to quote Only show this user #8 · Oct 10, 2009 If that fails, try hammer. :broon:
R R25Silver Discussion starter 3,481 posts · Joined 2008 Add to quote Only show this user #6 · Oct 10, 2009 Is it possible for someone to post a picture up of where the bolts you are talking about are?
Stu 53,503 posts · Joined 2002 Add to quote Only show this user #7 · Oct 10, 2009 Either end right underneath the lip. You can't miss them.
L LORDPSK 2,547 posts · Joined 2007 Add to quote Only show this user #10 · Oct 10, 2009 check heater resister is ok whilst the glovebox is out
R R25Silver Discussion starter 3,481 posts · Joined 2008 Add to quote Only show this user #12 · Oct 10, 2009 Replaced the heater resistor today.
