HOW TO: Install Daylight Running Lights (DRL)
1 reading
22K views 59 replies 22 participants last post by  Brownstone1892
Going to edit this post as I go along. Only done prep work today whilst watching the Toon vs QPR.
Soldered wire to my switch and added a connector block on the end:
Used my Dremel on the blank from the dash ready to accept the switch:
Fits perfectly:
Will update when I do more on it.
Cheers,
BS...
Why do you need switches...? are you make your own light??
I bought my DRL's at a fairly good price and and they don't need switches, they automatically come on when engine is started, then dim down when lights are switched on.
here's pics: (CLICK TO ENLARGE)
the lights are made by well know company called ring. rrp ÂŁ45 all in with fitting kit. no switches, and only 3 wires to connect.
they are really really bright to in the day, photo doesn't do it justice. at night then, when lights are turned on they dim to just 30% brightness.
I thought i might be able to help if i post my guide :D
Im more of show pictures them words but i sure people will be able to understand me if they need pics i have send them
DLR setup
List of thinks you need
Lots of wire (cant think of the wire i used but it need to be able to take the power)
Insulation tape
In-line fuse
12v switch
Tea
Step 1: Disconnect battery then start with the left hand first run the earth and positive wire to the right hand side
Step 2:Cut in to the right hand side earth and positive wires
Step 3:Join them up i did this by twisting the wire tougher
Step 4:Get some more long wire then join positive and earth from the right hand side
Step 5:We should have left joined to right then positive and earth wire coming out
Step 6:Tape all the joined wires tougher so you should only be left with + -
Step 7: On you positive wire cut the wire but leaving some wire off the end to add the inline fuse
Step 8:Fine a clean place to wire the earth on the car body work
Step 9:Get some wire add it to the earth wire then run that inside the car
Step 10:Same as 9 from the inline fuse and battery run the wire to the inside of the car
Step 11:Add positive and earth to a switch reconnect the battery and test
Step 12: Once all working have a large drink lol :D
Cheers :D
#57 ·
Interesting thread.
Did you know that DLR is short for
DAY LIGHT RUNNING?
In other words these should come on with the ignition and dim or turn off when the headlights are on. They should be automatic, you shouldn't be able to manually switch them on and off.
Also are you sure you should be playing with electrics if you are going to twist wires togeather, either use crimp terminals or solder and heatshrink tubing.
