Can someone clear something up for me? A friend of mine has just bought a TF160 and is trying to replace a couple of led bulbs in his HLBL. I've tried hunting around for some information and found these two:
BPR160 from the MG-Rover.org forum explains how to replace a bulb in the F's high level brake light - "Undo the 2 screws which hold the HLBL in and remove the connector. Undo the 5 Phillips screws and gently pull the two halves apart. Bulbs are 286's."
KrisFX-
So, if anyone has an annoying dull gap in their brakelight, just go to Halfords and buy these for ÂŁ1.79 each!
284 Exterior/Interior Bulb 12v 2.3W
Should i be using 284 or 286?
Also, is there a how to for getting the HLBL unit off?
Cheers all
KrisFX-
Cheers all
