My ZR (2004, 1.4 Petrol) heater is not working. The car has two symptoms to discuss.
Symptom 1 - For a while now the fan only works on setting 3 & 4. It blows air on those settings and is hot but doesn't blow air on setting 1 &2. I know the problem is the Heater Fan Resistor pack and I will get a new part and replace it. I also know how to do it because of an excellent thread on this forum.
Symptom 2 – Today I developed another issue. The fan is blowing as described on 3 & 4 but now there is only cold air coming through. The engine temperature level is reported as normal, the coolant level is slightly below Max, and the engine was warm but not hot to touch after 7 miles driving. I do not think it is a coolant/overheating problem.
So my question is this – The faulty Fan resistor pack causes the first problem but could it also cause problem 2? Can a faulty fan resistor pack cause the air to blow cold?
