any ideas the car was fine before this fault and would be a shame to get rid as its a lovely car? car starts and runs but then cuts out showing the ep message and then wont start, the ecu was read and was told there are no error codes? cheers
EP usually allows limited operation - excluding certain gears. Assuming this is an intermittent problem, I would suspect an electrical issue - bad contacts on the connector have been reported.
Maybe the auto box's own ECU has stored an error code. This may not be passed to main engine management system (commonly called ECU) which your garage may have read. Was it taken to a MGR service place?
