engine temp
1.1K views 6 replies 6 participants last post by  rich_b
Hi all,
just out of interest about every 4 weeks my engine coolent level drops from the max mark to the min mark and need topping up every 4 weeks. Is this normall? or is this the head gasket on its way out?
thanks
#4 ·
You should track down this leak before it catches you out, because then you WILL have head gasket failure.
The other symptoms mentioned are oil in coolant, coolant in oil, heater not working, boil ups etc.
Try taking the belt cover off and checking the water pump for staining. In the meantime, make sure you are topping up with antifreeze or the concentration will fall.
Theres nothing casual about coolant loss, it could be leaking/weeping, anywhere on the coolant circuit. If you are not taking immediate action you must increase the times you observe and top up the level.
Look for dried anti-freeze staining around the coolant circuit, including the radiator. If at any time the heater stops blowing heat, corresponding to engine temp, regardless of gauge reading, pull over and inspect level, through bottle, if low, let engine cool down before removing cap and topping up and bleeding system. Anything you don't understand........ re-post.
Also heed the advice by Diesel 1955.
