MG Maestro testimonial with permission to print
Star Cottage,
Forest Road,
Bream,
Glos
GL15 6LX
www.modelboatbuilder.co.uk
JDavies278@Aol.com
01594 564627
29/01/06
Dear Sir,
This is a completely unsolicited testimonial. Ametech engine restorer really does appears to work. Here’s the details.
We run an MG Maestro 2.0L efi (not the turbo) because it is comfortable, a good load carrier, was absurdly cheap to buy, has a 2 litre fuel-injected engine, power steering, and enough performance to keep up with today’s traffic. Family and work commitments mean we do a lot of miles.
As the engine came up to 100,000 miles, it began to use a noticeable amount of oil. This was very much more marked on long journeys involving sustained high speed.
At 104,000 miles, I carried out an oil and filter change, adding 500ml (two cans) of Ametech engine restorer, the recommended amount for a 2 litre engine. At a little over 105,000 miles, I accidentally kerbed the car and put a pin-hole in the sump. I eventually got the sump welded. This, of course, meant it had to come off. Another, unplanned, oil and filter change was done, at 106,000 miles. However, unavoidable commitments meant that for about 850 miles we had to keep driving the car, topping up constantly with cheap oil (The car got through several gallons of this stuff!). This second, unplanned, change at the sump repair was done without Ametech, refilling with Castrol GTX high mileage, my normal oil.
However, even though the Ametech was not in the engine for very long, it seems to have had a very marked effect. Yesterday I did a little under 350 miles, much of at speeds between 85 and 95 mph. The car used a little over half a pint of oil, which I find very acceptable. Before adding Ametech, say at about 103,000 miles, I would have expected to use at least four times that much, even using a good quality oil.
I have always been very sceptical of “magic potions” but I am convinced enough to write to you about Ametech. I will certainly be using it at the next oil change at 112,000. Please feel free to use this account any way you like, in whole or in part.
With best wishes,
John Davies.
