EGR valve
3.5K views 19 replies 8 participants last post by  JonathanP
I've just read some previous posts about disconnecting and plugging the egr valve but where about is it located and what does it look like??
Just curious to see what difference it will make to the running of the car
Also what effect would disconnecting the MAF sensor have on a TD? I was told once that it can increase performance slightly but can also cause black smoke?
thanks for the help :)
NO NO NO NO!!!!
Don't disconnect the MAF sensor! It's a vital component for the fuelling quantity etc! Forget it. I see plenty of cars with buggered/contiminated MAF sensors and they suffer from POOR performance!
The EGR valve makes an annoying metallic clatter noise sometimes; I have to demontrate to customers it is nothing to worry about and send them out on a short road-test with it diconnected to demonstrate (a)That it is nothing to do with the 'tappets' they all seem to think it is and (b)I'm not a lying sod!
Sometimes, pulling the vacuum hose enables an easier MOT smoke test pass, but it's not often required.
If you look at the engine, you have a large acoustic cover on top....follow this to the back edge and peek underneath the back edge - you should see a bright capsule with a small bore black vacuum hoses going to it's centre. That's the EGR actuator - the valve is underneath it.
I wouldn't bother playing around with it.
#4 ·
thanks for the info :)
Reason I asked about the EGR valve was that I have a bit of a flat spot at low revs and it sounds like the EGR is operating
was going to disconnect the EGR to see what difference it made
still not to sure what the egr valve looks like so I've attached a pic of what I think you mean (probably something totally different)
I've also indicated both ends of the hose you would normally plug the top end??
In my experience id disconnect the damn thing, mines smeged it was causeing lots of smoke when i was cruising at a steady speed.
Disconnect it while the engines running and you might even hear the engines sigh of relief ,disconnect the WIRING CONNECTOR not the hoses just leave them alone.
The engine will run perfectly well without it mate.
where is the wiring connector, is it shown in the picture??
See in the pic above, see the little plug on the EGR solenoid (the thing with 2 vacuum hoses goin into it) with 2 wires comim out of it?
The wires are colour coded brown/orange and red/grey.
In my experience the car picks up a lot better with this thing disconnected but leave the vacuum hoses in place, infact remove them and make sure there not blocked and reconnect them.
Let me know how you got on.
thanks for the info guys :D
I unplugged it last night and did notice quite a difference, more than I thought I would but this could be because the engines tuned.
I think the EGR valve might have been causing the problem with the first tuning box, as the car would shake when idling after a cold start, maybe the EGR was coming on when it shouldn't??
Which tells you (the driver) that something is wrong with the engine that could cause an increase in tailpipe emissions.
If you pull the wire from say, the purge valve on a new car, the MIL will soon come on....
I think the same would happen on a modern Diesel, too. That's where the ball bearing trick comes in!
#14 ·
BEWARE
The EGR valve is fitted as an emmisions control
measure. Its purpose is to reduce the output of
NOX gases from the exhaust. It achieves this by
recycling roughly 10% of the exhaust gas output back through into the inlet manifold.
More critically this has the effect of weakening
the fuel mixture (less oxygen, less NOX) and thus reducing the temperature in the cylinders and in turn of the exhaust valves and manifold.
This should increase the reliability and longevity of your L-series engine.
Therefore havind the EGR valve disconnected for a
long period of time may have a detrimental effect
on your engines long term health because of the
increase in the combustion temperatures
I unplugged the connector indicated with the red arrow and the 2 wires coming out, if you wanna unplug the vacuum hose and plug it with something like a ball bearing like dr dave said I think its the one indicated with the yellow arrow
I think your supposed to plug the end furthest away from the connector, it's probably better to do this than unplug the connector as it shouldn't log a fault code
as for how long you should run it like this I dunno, depends how hard you drive the car, the harder you drive it the more it could stress your engine
