Earthing & Starter Motor problem
4.3K views 35 replies 5 participants last post by  Pricey888
Hello can someone please help. My car's has had an intermittent starting problem. Now if I moved the black negative wire on the battery it would start up first time. Now I have taken out the negative wire from the body and the bolt looks passed its best and when I put it back together it just doesn't have enough power to start. This is with a brand new charged battery. Could this bolt be causing this. I've ordered a new one. I believe it would as I'm guessing the bolt is used as a conductor.
Thank you
You probably won’t need to replace the bolt (if it is the problem), it probably just needs a good clean with a wire brush. Take it back to shiny metal, spray it with something like WD40, refit it, then coat the area with Vaseline.
Just as likely to be your problem is dirty battery terminals. Follow the same process as described above and that should see you sorted.
Good luck
Why would you randomly replace the alternator?
Go back and read again the first sentence of your opening post.
Good luck.
Hi everyone thanks for your help. This morning before I've cleaned everything up. I've reattached everything. So I'm getting a 12.6v reading from the battery which is fine. I'm getting a 12.6 reading from the negative cable into the body. But I've I put the multimeter reading on the bolt into the body I'm only getting 4v should this be 12v aswell
Hi everyone so I had a new starter motor fitted. About 2 days after I went to start the car and there wasn't enough power to start then 5 minutes later it started first time. It did this a couple of more times. The one day I drove it went back 20 minutes later and it was completely dead. I got it going and it did this again. I thought it was the earth cables so cleaned them all but now the car turns over but doesnt fire. Battery is fully charged. Could this be related to the new starter?
If the car turns over it is not a starter issue. However; your starter issues you mention would likely to be the cable to the solenoid which has has a female spade connector to connect to the male connector on the solenoid. This connection does tend to be temperamental, usually just closing the gaps on the female connector to make it have better contact on the solenoid connector is enough to sort it out, but as you now say the engine turns over but does not start would indicate a different problem. All I can suggest at this stage is for you to turn on the ignition and listen to see if you can hear the fuel pump prime, if you cannot hear that occur it maybe the fuel pump is dead/no power
#19 ·
Read this post after replying to your other post. If these issues have only started since you had the starter changed by a garage I think you should get the garage to check their work.....unless you saw a new starter being fitted out of a box you don't know if a fitted a recon or a new one. Plus new or recon can always be faulty
#27 ·
I'd get the garage to check the cable connections on the starter motor, could be they didn't do the nuts up tight and are loose, could be there is a short in the circuit, especially of lights are dimming. A fully charged good battery shouldn't have the dash lights dim when turning over...maybe dip beam, but then, never tried turning my Tf or F over with the lights one so don't really know
