CVT gearbox problem
8.3K views 6 replies 4 participants last post by  htr
Hello All.
Can someone tell me what other vehicles share the same CVT with the Rover 25. Mine's a 2003 1600cc. I think the Ford Focus has one, but is it he same. What about the 'BMW' Mini range?
Is the CVT controlled electronically?
Could my CVT / car problem be software related?
Can the service agent upgrade this via a computer?
My '03 25 [1.6 CVT with 60 km on it] has been running very sweetly. I travel about 100km to and from work every day in it and I'm really enjoying being back in a Rover.
But, on start up for the homeward journey today [last Tuesday] the car began to run very roughly. The motor performs well but there is no power and the acceleration is at best snail-like. Sport mode doesn't happen and I crept up the few hills that I normally bound over.
There have been no problems to date.
I browsed a variety of threads / topics in the forum. Some comment on CVT fluid needing changing. Some talk about a sensor being faulty.
Fluid level while hot [ie at the end of the trip] was halfway between the two nicks in the dip stick. Colour is red [like a strawberry!] and smelt ok too.
I'm the second owner. The car has been dealer serviced since new.
I find it hard to believe the fluid could be faulty as these transmissions have fewer moving parts than more traditional transmissions. Sensor faulty???
Like I said, this situation had a sudden and unexpected onset. Symptoms again: struggles to accelerate, very little acceleration, CVT doesn't work in 'manual' mode, it's like leaving the hand brake on [which it isn't!], engine 'labours' in drive and the rev's struggle to pick up to 2000, and while cruising are about 1100rpm [usually about 2100], slowing to corner or come to a stop there is a juddering and I feel that the engine may stall [it doesn't] - a bit like coming to a halt in a manual but still in 3rd or 4th gear. Reversing is a struggle too.
The engine starts ok and idles perfectly in P or N. Could a faulty ignition component be the root cause? Performance has been spot on to date and no missing or misfiring etc.
I suspected the lambda sensor. These can fail and effect the air/fuel mix. I have a coolant leak which I suspect is a faulty inlet manifold gasket [there's no oily residue in the header tank, or bubbles appearing in it either as you would expect from a faulty H/gasket]. The silicates in the coolant mix can coat the sensor and render it inoperable. Gasket replacement scheduled for next week [and OAT type coolant going in too].
The Coolant temp' sensor has also been suggested but I haven't explored that yet.
Can the CVT jam in one 'gear'? I realise there are no gears but can they jam in a high ratio? Maybe a road speed or engine load sensor failure making the ECU think it's on the open road???
The more I think about it the more I suspect an electrical / electronic fault, but I haven't the foggiest as to where!
Hi,
no, no warning lights on dash. I've just come back from an auto electrician who was able to 'plug in' and read the car. Two codes came up, P1787 "CVT ratio control motor" & P 0340 "camshaft position sensor"
He cleared these and rechecked. But the car still has the same problem. Happily his brother works at a Rover agency and he's asked him to look into these. They could indeed be old and erroneous codes, however the CVT code would appear to be very close to the culprit.
Now, how to rectify the problem? Happily the small town I live in has a very good auto tran's mechanic whom I've known for years. He knows quite a bit about CVTs. So between these two people and the info' I've gleaned from this forum I feel a whole lot more confident.
I'll keep the forum posted.
Hi,
What is the name of the CVT Mechanic and where is he based? I need some urgent work doing too.
Hope you get your problem sorted. It seems to me these CVT Gearboxes are a pain in the a*s!!
