hi all
i need some opinons, on my mgf 96(n reg) the cooling fan seems to be coming on early and then doesnt switch off until i knock off the ignition,when i switch the ignition back on it runs for a few seconds then goes off, i cant quite work out why the fan comes on as its cold out and im not sitting in traffic its always as i reverse onto my drive but i have been on the move for all off the journey up until then.
the worry guage is is the middle, the same place as always,the thermostat appears to be opening as i have heat in the pipe to the radiator and heater matrix, the heater in the car works ok. I dont think there is an air lock as i checked the radiator bleed nipple.
could i have a faulty sender stat?
could the thermostat be stuck partially open? therefore keeping coolant temp up but not sending enough to rad for cooling
or this normal for an mgf,
whas there an option to use a sender stat with a lower setting to bring the ecu to start the fan earlier?
what are your thoughts please.
regards
matt.
regards
matt.
