Coolant Loss from Reservoir
579 views 6 replies 4 participants last post by  Man in the Car
Hello All,
My previously well behaved 1800cc MG ZR Auto has been parked up for a few months. On starting up recently for a pre-MOT trip round the block, it was forcing coolant out of the coolant reservoir as it pulled back into the garage. Also, the coolant colour is now rather murky as opposed to it's previous clear pinkish-red.
Does this spell certain Head Gasket failure?
Best Regards,
Andy
Not HGF for certain would think, but it certainly doesn't sound good - it could possibly just be an air lock or some other blockage in the coolant system causing overheating/boiling (having been stood for a lengthy period, a stuck thermostat is a possibility), but to me it does sound rather like leakage of exhaust gases into the coolant past the head gasket. If so you are likely to have significant residual pressure in the system when it has completely cooled, and/or may find a significant amount of coolant disappears too (when cold, take each of the spark plugs out and check for any signs of coolant in the cylinders).
A 'sniff test' with an exhaust gas analyser can aid a positive diagnosis of fire ring HGF, but as there is always some hydrocarbon contamination in the coolant, it can't be used to discount the possibility altogether.
