changing the charcoal canister
11K views 19 replies 7 participants last post by  48365
the old one is coming out cos it is just doing my head in know, and seeing as how i just got one off the bay for 99p i might as well .
is there anything special i need to know, or is this just a plug and play job. should i also consider the fuel filter as well?
Why remove the charcoal canister? Every MG rally or track car i've built uses them, just a smaller/lighter metal equivalent.
Without it your fuel economy will go down and more importantly the car will smell of fumes all the time. I expect you haven't ever driven a hot rally car / track car for miles on end when its "fumey". You start to feel pretty sick after the first mile or so.
Basically to remove weight the rally car is in a limited mod formula, so i need to loose as much weight as possible.
It only absorbs the fumes from the tank, to stop them venting to the atmosphere, and feeding them to the engine at certain engine speeds/throttle positions.
My thoughts are to remove it all and vent the tank to the atmosphere
Saves weight and one less thing to go wrong.
Exactly what Ashy said.
I've built countless ZR rally cars in the past. And there's an extent you can strip a car, then when you go past that it becomes pointless. You're doing this.
If you're that serious about weight, change to S class and then you can do things such as perspex windows, fibreglass boot + bonnet (which are readily avalible for the ZR), cutting out the insides of doors etc.
#15 ·
It does remove a fair amount of weight, but not as much as people expect. The reason it should be stripped in all rally cars (and if they're scrutineered properly it would have to be else they would fail), is due to it being rather flammable. Thus it's not allowed in the car the same as the interior.
I think fully removing all the sound-tar and foam in the doors/quarter panels you save just shy of 2KG. Which in reality if the driver and co-driver took a "large dump" before a rally would save the equivalent hahahaha
