Car + Floods = Bad :/
1.5K views 21 replies 10 participants last post by  LORDPSK
Hello my car hero's!
Lets say a diesel car went through several large puddles (bloody floods where I live), then finally went through one and stalled, had it towed home and now it won't start..
Took out air filter and it was soaking, water may have gone down further i'm guessing :(
What would be worth a shot checking to get it started before having it go to the mechanic to check the head / cylinders for water? Oil has no sign of water though.. :/
Sounds to me if the filter is soaked that it has tried and most likley succeeded in sucking in a nice helping of water into the engine!!
But, have you also check to see if the water has caused any electrical faults that could be stopping it from starting?
screwed fuses/Relays/ECU?
Anything unusual at all when you click the key over before starting?
if there was water in the pistons it sounds like it hydrolocked. bent conrods are not uncommon when it happens im sorry to say :(
if water squirted out id make sure they were completely empty of water before trying to start it again
good luck.
It must have been very deep puddle for a 25 to take water through the air intake, I have had a MGZT that had 2 cracked linears and 8 bent valves because of water being sucked in but there pick up is low down, the insurance wrote that car off becuse the engine was competely gone
And the answer is from the mechanic is (apparently).. Water in the engine from the air intake managed to get down into the engine and mess up the timing of the car by making it skip a bit? (cog skipped a little?) so its not timed correctly so not starting.
Apparently there are alot of bent valves, rods, etc though :/
It sounds like it is sooo close to starting though, just needs that little tiny touch of life :(
Soooo its having another look at tomorrow to see what the story is but I doubt she'll be gone for good. But fingers crossed
Thanks for the help everyone! :)
