1. Remove hand brake
2. Wind back nut under ash tray
3. Loosen the wheel nuts, chock car & jack it up, remove rear wheels.
4. Clean calipers and brake area with brake cleaner.
5. Remove necessary bolts, two hold pads to caliper the other two hold the caliper to the hub, not sure which size.
(Can be quite awkward as the brake hose is in the way I had to put a breaker bar on the end of a socket wrench).
6. Remove grub screws and remove discs.
(I had to drill the grub screws out of the hub on one side, the Phillips head rounded off with one turn of the screw driver. I never expected it to be that soft.)
7. Clean hub apply copper grease to it and fit new discs then clean with white spirits. Could paint NON contact area with Hammerite but must leave to dry.
8. Remove old pads wind piston back into caliper.
(The hardest part, can use a big screw driver or a large file at an angle. I did it but the rubber grommet split and the piston ended up rusting so I had the caliper changed after a couple of months.)
9. Grease and fit new pads, shims and fit to caliper.
(Don't use copper grease on the rubber)
10. Bolt back in position careful not to cross thread the bolts. Can paint caliper to stop rusting but again must leave to dry.
11. Pump foot brake to bring pads up to the disc.
12. Pull back brake cable arm spring to full travel and check seating.
13. Set hand brake one notch and tighten cable under ash tray. When the wheels start to resist turning, drop hand brake and wheels should turn freely.
(Important to do in the correct order or the hand brake won't work.)
14. Fit road wheels
15. Admire, drink tea or other beverage of choice.
16. Test brakes and drive carefully until they bed in.
Fronts I haven't done yet but would be similar but without the brake cable. All in you should start in the morning should be done in no time, quicker when you know what to do and when the components aren't rusted.
Good luck hope it doesn't rain
