http://www.forbes.com/2010/02/23/flint-autos-toyota-business-recall.html?boxes=Homepagelighttop
Toyota and other carmakers should scrap electronic drive-by-wire systems.
The entire auto industry is frightened. It isn't about Toyota, replacing some floor mats, or shaving a bit off accelerator pedals or sticking a tiny piece of metal into brake assemblies. If those are problems, they are easy to correct. What's frightening is the ghost, the ghost in the machine. Might something in the electronic computer systems make our cars suddenly speed out of control, into some unintended acceleration?
We are skeptical of tales of runaway cars and unintended acceleration. Most of the time we believe drivers step on the gas pedal instead of the brake, don't realize it and press down harder when the car accelerates instead of stopping.
In the 1980s car controls became more electronic, but the throttle was still a cable linkage to the gas pedal. The computer could turn the engine rpm's up and down, perhaps causing an uncomfortable but still modest surge in engine speed, but not a runaway throttle. About that time, Audi was hit with unintended acceleration charges, but there never was any evidence. Still, changes were made so the automatic shifter can't be put into gear unless your foot is on the brake pedal.
You've heard of fly by wire, a predecessor to drive by wire. In 1979 the Air Force accepted delivery of the new F-16, the first fighter to use fly-by-wire technology. In the past the control or joystick maneuvered the plane by moving the control surfaces through direct mechanical hydraulic linkage. Now the stick was a computer input device.
