I am talking about the 25 and the ZR or 75 and ZT.
Apart from looks, and maybe springs and that any mechanical differencies???
Not really because if it is a body kit only the difference and a set of springs you cannot eat chalk by puting on it a set of sporty springs...ZR120 said:well thats like saying are they any differances between chalk and cheese excepty ones dry & white while the others orange, soft & edible
You 're a bit confused unfortunately...because YOU brought up chalk to the discussion.....so go look for the a.m. forum...ZR120 said:look if u wanna eat chalk go and discuss in on a chalk forum or summit.
the differances betweent the engines in the ZR is simple. The throttle body. upgrade to the 48mm metal one and u will go from 83bhp to 103bhp. the springs and dampers are stiffer on the ZR. i think it also adds the front anti-roll bar. it uses better bushes and wider wheels. the steering is also sharper on the ZR
Perfect Dean! thank you!Dean ZR 105+ said:The ZR is basically a tuned 25 with uprated springs, dampers, steering, cluch setup, anti rollbar, wheels, gearbox, airodynamics and on the 160 model it is tuned even more including close ratio gearbox, break upgrade.
So to answer your question yes the ZR is diffrent to the ZR.
Basically the ZR was developed for the person who enjoys a more sporty drive to a relaxed and refined drive its the same with all of the models (45,75, 75 Estate) are refined where as the (ZS,ZT,ZT-T) are the hardcore versions.
Steering too. My 53 reg ZR has much sharper, quicker, more direct steering than my previous 51 reg 25. The 25 steering felt heavily damped. Solid and dull.ashy said:IMO the main difference is the suspension and the badge, forget about the cosmetics they do nowt.
Drop a 25 and change it's suspension set up and put ZR 17's on and it more or less becomes a ZR.
Do you fancy that common bird off wife-swap?while the ZR is sexyyyyyy.
so is to easier to get a MG then mod a Rover. I was gonna mod my 400, but then I think it will be easer to get an ZS.parsec said:I drive a ZS180 and sometimes drive my dads R45 2.0 diesel.
Although they are based on the same car, they are a completely different from behind the wheel. The differences are huge - seriously.
Hope I win the lotto then, and soon! I want an MG ZSDean ZR 105+ said:It is a lot easier to but a Z thanit is to mod a rover plus in the back of your mind you still know its a rover and not a true MG
God I wish they'd made the ZR look like that in 2001 - imagine the sales.Dean ZR 105+ said:I had 2 25's before I had my New Shape ZR and the ZR really is a diffrent car to drive and yes it is sexy
D u like
