hi everyone, I've been having problems down changing into 2nd gear, it only happens after I've been driving 20 minutes or so, so once the vehicle has warmed up.
I can change between all other gears just fine. I can change up through all gears no problems. I can down change between all other gears no problem, it's just 2nd that I can't down change into.
I have today done the universal joint mod and the problem still persists, it's not every down change but when the problem is there the only way I can get 2nd is to change to 1st first and then back up to second, and the problem seems to be getting progressively worse in that it's getting more common.
I have even tried double dipping the clutch but when the problem occurs I still can't down shift into 2nd, and I have to go through 1st first.
I don't know if it's related, but occasionally when pulling away in 1st I get quite a bad shudder.
I do hope this is all clear, I have tried to give as much detail as possible.
