Hello Everybody, Especially Jonny Coupe and Ice,
I have a Rover 216GSI 1993, my cambelt has snapped and there may be damage to the valves so ive decided to go Vtec.
Do i put a vtec head on my lump or go for a full vtec engine? I think my engine is the D16A6 also known as D16Z2.
The spec is as follows:
Found in:
I look forward to hearing from the pros, not the people who argue over a serial code for an engine that nobody uses.
Thanks dudes!
Found in:
- 1988-1991 Honda Civic Si, CRX Si, Civic Wagon RT4WD
- 1990-1991 Honda Civic EX Sedan
- 1988-1995 Honda Civic Shuttle RT4WD (UK/Europe/Asia/AU/NZ)
- 1989-1996 Rover 216/416 GSi (UK/Europe)
- Displacement : 1590 cmÂł
- Bore and Stroke : 75 mm X 90 mm
- Compression : 9.1:1
- Power : 115 hp (86 kW) @ 5600 rpm & 95 ft·lbf @ 3,800 rpm, redline 6500 rpm (USA)
- Note: 1988 engines were 105 hp (78 kW), MY89-91 hp was increased to 108
- Valvetrain : SOHC
- Fuel Control : OBD-0 four-point PGM-FI
- Head Code : PM3
- Piston Code : PM6
Thanks dudes!
