ive just got in from having a little play lol my problem is why is a 1.4 standard keeping up with my 160 i think my cat might be buggered but i should be leaving him if not why am i playing my silly insurance? please help here thanks
There's a :fail: right there.the 1.4 has decat and s/s cat bk if u get me i will drop the oil out on monday and I've got a k+n cone on the end of the inlet and s/s cat bk
k series engones usually dont like it if you remove the cat, it likes the back pressure to keep the gasses flowing
is your cone filter right next to the engine? (common place is to put it where the air box was) this will give you less power than if you hadnt bothered, put it someware low down with a flow of fresh air, but wont get wet if you hit a puddle / it rains
Something is seriously wrong if the 1.4 stays anywhere near the 160.
Does it rev freely all the way to the red line through the gears?
lumpiness could be caused by loads tbh.
my prime suspects would be :
spark plugs
air filter (an open cone wouldnt rob you of THAT much, you should still skin a 1.4 alive)
coil packs
or inlet manifold gasket leaking. do you lose a small amount of coolant?
A decat definately loses power, I have a vvc in my 200, I dropped the cat off and fitted a straight pipe and it was all noise and no power, my pals 1.6 metro kept up, as soon as I fitted the cat again it left the 1.6 metro standing. put your cat back on
if you find out why your car is lumpy let me know, mine has become lumpy over the last 3 days, I've recently fitted a FSE fuel pressure regulator with and alloy fuel rail and it's only developed since then so maybe I've done something wrong.
