1 - 8 of 8 Posts
mg_zt
Since I bought my ZT a month ago I've started to notice a few squeaks on the clutch pedal, and it is very stiff. Sometimes it also seems to jump a little. I guess this could just be the clutch cable. Is it an easy job?
Anything else I should check b4 buying one? Or a way to make sure it's the issue?
I don't think there is a cable to the clutch.
It sounds as though the clutch pedal bushes are dry or wearing out. If not it could be the master cylinder piston is becoming worn.
There is no clutch cable - it's a hydraulic system. The noise is normally just from the pedal box and is nothig to worry about.
Mine has started to squeak, but only since I topped up the master cylinder, think mine's just the spring though on the pedal
How did you manage this, reason I ask is that the clutch mater cylinder is seperate to the one for the brakes?
Edit:
In fact I know its seperate, because when my clutch went on a previous ZT (symptoms simillar to snapped cable), the brakes still worked as normal.
The manual is confusing regarding this stating that the clutch and brake fluid is linked. But from what I remember, you are correct in saying that they are seperate. The clutch master cylinder is awkward to get to but Simonauris did top is up via a syringe and tube method.
1 - 8 of 8 Posts
