So I found a rust hole on my ZS a couple of weeks ago.
This week I had it checked out for welding at a local garage. The conversation started with “do you realise how bad it is” ... :-/
After some poking the rot went around the inner wing and behind the front suspension.
It is fixable, it’s only metal after all. But it’s turned into a major job. The mechanic says that the subframe will need to come off to do the welding, plus steering rack, exhaust, etc. - first question is, would we on the forum agree that’s true (from the pictures)? He’s made it clear that he expects bolts to snap and it to become a tricky job.
The estimated cost is several times more than what I was offered on the car in trade-in four years ago! If this was any other car it’d be on the way to the scrapper! But I’m pushing ahead with it.
At the moment, this is the only problem area. The rest looks solid but there is plenty of surface rust.
So since much of the front is coming apart, I’m looking to replace as many parts as is sensible to do and do a mini-restoration job. I’ve asked the guy to strip as much rust as possible while it’s accessible and re-paint and re-seal the underneath.
I’m also intending to give him some new parts to fit - anything that looks bad, or anything that would be expected to be bad after 14 years. My shopping list looks like this so far:
I’m not looking to replace the suspension arms as they look rusty but solid. I’ll try to clean those up, repaint and refit.
I’ve had difficulty finding some basic parts - like the castle nut for the lower suspension ball joint RYH100420. I’m sure these are available elsewhere if I knew the size/thread type, but I can’t find that information!
Mostly I’d like everything from here:
https://rimmerbros.com/Item--i-GRID003093
https://rimmerbros.com/Item--i-GRID003096
https://rimmerbros.com/Item--i-GRID003097
https://rimmerbros.com/Item--i-GRID003690
So this is a general call for help - what’s worth doing now, what should I be doing? My budget is not unlimited but I’m willing to spend enough to get my car back up to standard.
Pictures of the rot:
ZS work, July 2018 by tkgbbs, on Flickr
- Every nut and bolt in the anti-roll bar, steering rack and to re-attach the subframe.
- New ARB, 24mm. Current one has surface rust.
- ARB mounting brackets.
- ARB bushes.
- Lower arm bushes.
- Radius rod bushes.
- Lower ball joint.
