4.4 metres IIRC... the saloon looks a lot longer, but a lot of it is simply in the design whereby the boot is a more prounounced extension of the car.
Hope this helps
John
Hope this helps
John
Test drove both hatchback and saloon in 120 form and found the saloon a little sluggish. I have sensed that the saloon is slightly heavier?sheddist said:There is more luggage capacity on the saloon than the hatch. Wacky
You get 3 real seabelts in the saloon rather than the lapstrap in the centre with the hatch.
Saloons are stiffer - --- Comments?
Thanks EssexMGR.EssexMGR said:The ZS Saloon is 4540mm long, whereas the ZS Hatchback is 4386mm long.
They are both 1923mm wide (Including Door Mirrors), and 1386mm tall.
Strangely, the Rover 45 Hatchback is 4390mm long, whereas the 45 Saloon is the same at 4540mm long.
Actually 4 door is assumed to be heavier due to the extra length.bluezs said:Would guess the extra weight in the 5 door is due to the framework around hatch aperture.
