My 180 is about 10-15mm lower on the driver's side than the passengers side. I've had a look over the components and everything looks in good order.
Top mounts look fine, bushes look fine, and control arms look fine. The only thing I can think is that the coil spring has worn out and compressed a little, but I have never heard of this before. Is it likely?
The only other thing worth mentioning is that I loosened and tightened the lower control arm bushes a while back. I pinched them up with the front on axle stands, jacked the drivers side wheel until it took the weight, and then torqued the bolts.
Is this correct, or should I have jacked both wheels to take strain off the anti roll bar?
Thanks for any assistance or guidance.
