1 - 9 of 9 Posts
ZF Develops Automatic 8-Speed Transmission for Passenger Cars
* Presentation to 1,000 engineers at the Vienna Motor Symposium
* Consumption savings of six percent thanks to the new transmission concept with improved efficiency.
* More power with same installation space.
* Kit system for future hybrid and all-wheel drives
ZF has designed a new automatic transmission generation for passenger cars: With the automatic 8-speed transmission the chassis and driveline specialist succeeds once more in combining seemingly contradictory goals. The automatic ZF 8-speed transmission allows for additional fuel savings of approximately six percent compared with the already optimized automatic 6-speed transmission of the second generation. This is achieved above all by a completely new transmission concept. At the same time, the automatic 8-speed transmission transmits more power in comparison to the previous model, but still gets by with the same installation space and does not require more components. Last week, the new 8-speed transmission was presented for the first time at the 28th International Vienna Motor Symposium.
“Our main development target was to find a transmission concept which allows for significant additional fuel consumption reduction and thus offers tangible added value to our customers and drivers without making any compromises in terms of performance”, explains Dr. Michael Paul, ZF Executive Vice President, Technology and Group Executive of the Car Driveline Technology division. “The number of gears was not given top priority.”
Fuel consumption savings as development target
The new, more powerful ZF multi-ratio automatic transmission allows for consumption savings of six percent. This means that the excellent consumption values of the second-generation automatic ZF 6-speed transmission which entered volume production only in 2006 have been further improved considerably. To make it clear: Compared to an automatic 5-speed transmission which is still widely used today the consumption reduction amounts to approx. 14 %.
Two innovations are mainly responsible for these spectacular consumption values. Compared to the automatic 6-speed transmission, the basis of the new ZF automatic transmission generation is an entirely new transmission concept featuring four planetary gear sets and five shift elements. Only two shift elements are opened in each gear which leads to considerably lower drag losses. Besides the improved efficiency, this transmission concept features a higher total ratio. Modern torsional vibration damping systems in the torque converter also have a positive impact on consumption and CO2 emissions. These systems also allow for a quick lock-up of the converter clutch in the second generation automatic 6-speed transmission presented in 2006. Furthermore, ZF now uses a small vane cell pump mounted parallel to the axle.
Versatile combinations
Another development focus was the increase in performance. The power-to-weight ratio of the new automatic transmission is higher and can transmit a higher input torque at the same weight, in comparison to the previous model. The automatic 8-speed transmission gets by with the same installation space as the previous versions made by ZF. In terms of shift comfort, response and shifting speed, also the new automatic 8-speed transmission operates at the already very high level of the second generation of the automatic 6-speed transmission.
The equipment options offered with the new automatic 8-speed transmission for passenger car driveline technology are trend-setting. The new transmission has been designed in such a way that it can serve as a modular system for further starting and all-wheel concepts without changing the basic transmission concept. This way, a torque converter could be replaced by new clutches or could be omitted completely when an integrated starting clutch is used. The design engineers of the automatic 8-speed transmission have also paid attention to the compatibility with today’s and future ZF all-wheel concepts.
For the hybridization of the driveline, the automatic 8-speed transmission offers the possibility of implementing both a micro hybrid with a crankshaft starter generator and a full hybrid in the form of a parallel hybrid. All known hybrid functions can thus be implemented in combination with the new automatic 8-speed transmission.
You simply do not need 8 forward gears in a car.This need for more gears than you attitude is barmy.I am waiting for the company who is first to bring out a range change/splitter box for a car!!!!!!
Don't more gears tend to compromise smoothness? If the transmission is constantly shifting, there's going to be some sensation of it in the passenger compartment. Whatever happened to the good old 2-speed autos like Chrysler's PowerFlite?
This is being driven by emissions legislation more than anything. Adding more ratios is an easy way to bring down the CO2 g/km figure.
Several manufacturers of vehicles with high CO2 outputs are already trialling this new ZF 8-speed box.
As for more ratios having an adverse effect on NVH and passenger comfort, I suppose it depends entirely on the gearbox/powertrain combination. The ZF 6HP26 6-speed box shifts completely imperceptibly when coupled to the Jag/LR V8, and I've no reason to believe that the 8-speed unit would be any different.
1 - 9 of 9 Posts
