Once again another emissions failure on CO. (MGF 2000)
Ran the check program on live data and saw a potential problem with the lambda (default reading 0.435mv check sensor),
Changed Lambda still the same ??
Did a 2 wire check with the ohmmeter and as the Lambda warmed up readings varying between 0.2 and 0.9 which for me shows a good Lambda
Checked with computer again still no readings and default message still showing
Checked wiring continuity between Lambda and ECU shows good
Car runs fine but a little rich, Now what
